Schön Veranschaulichung der Schritte, die nötig sind, bis ein Modell fertiggestellt wird:
ZitatAlles anzeigen"pandora-model"
Let me share some infomation about this.
1. Make the 3D drawings on the computer according to the datas supplied by the original car maker.
2.Output the computer datas to be meausred and get ready for shaping plate.
3.Make all the parts(clay) of the shaping plate according to the measured results.
4.Assemble all the clay parts into a CAR and send the clay car model to the real car maker for check. After approvement, the car model can be put into production with authority.
5. Start to make the molds.
6.Clean the molds thoroughly to guarantee the smooth surface of the products.
7. Assemble all the parts of the molds. The molds will be tested by the quality-control technicians, if any defects with the molded products, the molds have to be re-made.
8. The following steps can be divided into two parts, car body parts and chassis parts.
CAR BODY:
Inject the alloy into the molds and the car bodies formed.
sanding, polishing and painting
CHASSIS:
Make the chassis and make the plastic parts
Get the plastic parts for size-cutting
Process the interio-decoration parts carefully.
Process the car windows, engines in detail.
9. Finish the CAR MODEL with assembling the car body parts and chassis parts.
